gears to PENNZILLA
Old May 1, 2001 | 10:57 AM
Slinger's Avatar
Pennzilla, I don't think your e-mail site is working properly. I can't seem to reach you and noticed that someone else in this forum had the same problem. My question is: When you were talking about having new gears cut did that mean have some new ones made for your transmission? If so who does this and how much does it cost?
Old May 6, 2001 | 02:23 AM
PENNZILLA's Avatar
TUDORS DOES THIS SO DOES CT, I HAD MY GEARS UNDERCUT A LITTLE SO I CAN SHIFT FASTER WITHOUT THE CLUTCH WHEN HILLSHOOTING A DUNE. AS FOR COST I DON'T KNOW BECAUSE I HAD OTHER WORK DONE AT THE SAME TIME. I DO KNOW THAT MOST PLACES CHARGE 175 JUST TO SPLIT THE CASES. AS FOR MY E-MAIL I FIXED IT AFTER THE LAST POST THAT BROUGHT THAT TO MY ATTENTION. I HAVE BEEN GETTING MAIL BUT I WILL CHECK IT AGAIN.
Old May 6, 2001 | 04:20 AM
Slinger's Avatar
You had your OLD gears cut or you had some totally NEW ones made? I already have the cases split and have the gears out. The ones I have are worn pretty bad and some are even missing some teeth from a prior chain-binding incident.
Old May 8, 2001 | 08:12 PM
PENNZILLA's Avatar
YES I HAD MY OLD ONES CUT. YOU CAN GET NEW ONES FROM THE FACTORY IF YOURS ARE HOUSED. CALL TUDORS OR CT AND SEE IF THEY HAVE THE AFTERMARKET SETS AVAILIABLE. I KNOW A WHILE BACK THERE WERE A COUPLE OF PLACES THAT MADE GEARS FOR THE 250 NOT SURE ABOUT THE ZILLA. TUDORS IS THE ONE WHO CUT MINE BUT THEY WERE IN GOOD SHAPE.
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
