LT125 cold start
Old Mar 7, 2022 | 07:42 PM
scarycary's Avatar
Default LT125 cold start
I inherited a LT125 quad. I got it running. It won't start without starting fluid. Once warmed up I can pull start it easily. I've cleaned the carb twice. I replaced the primer diaphram. Fuel pump seems OK. What is typical for starting procedure? How many pulls on the primer? On a cold motor I always use the choke. All help appreciated.
Old Mar 8, 2022 | 02:08 AM
Do a compression test and check valve clearances.
Old Mar 8, 2022 | 10:32 AM
scarycary's Avatar
I'm going to guess 80-120psi for compression is acceptable?
Old Mar 9, 2022 | 01:45 AM
Yes, minimum of 80psi.
Old Apr 4, 2022 | 04:32 PM
scarycary's Avatar
Default compression good
I had to get an adapter but the compression is 120psi. I'm still wondering how many pulls on the primer?
Old Apr 5, 2022 | 03:06 AM
I don't know the model at all, but note on later carbs there are two plungers as well as the choke, so Suzuki may have had problems with cold starts. Primers on Hondas are push in rather than pull out, too. I would be tempted to buy a cheap Chinese carb for it (fairly amazing they make them for a 40 year old bike,) and see if you still have the cold start problem with it. Other causes can be manifold leaking and crankshaft seals, not sure about reed valves if it has them. Jack (LT80) knows far more about 2 stroke Suzukis than I do.
yo
Dec 4, 2003 08:39 PM
KXROM
May 13, 2002 04:53 PM
special
KTM
11
Apr 18, 2002 09:49 PM
love250x
Dec 21, 2000 09:54 PM
