Sound from coil no start
Old Aug 21, 2022 | 05:05 PM
Donkeyguy7's Avatar
Default Sound from coil no start
Hi, won’t start. When I put the plug to the engine and turn over to check for spark, it might initially spark once but then nothing. Then even without turning the engine over, I hear a snapping sound from the coil and if I touch the plug I get a shock. This is without turning it over! Any ideas?
Old Aug 22, 2022 | 02:22 AM
Could be your coil or HT lead shorting, though you wouldn't then get a shock from it. Try a new plug, if that doesn't work, get a new coil & ht lead. A cheap Chinese version for your model, should be OK to check it out. To be scientific, you could check if you are getting high voltage pulses between coil leads from CDI and earth, when you spin the engine over. This can be well over 100v so be careful.
Old Aug 22, 2022 | 03:21 PM
Donkeyguy7's Avatar
Default Thanks
As soon as I put the ground on the battery to power it, I hear the coil noise so strange.
thekidwithquestions
Jun 3, 2022 01:47 AM
go-hard-or-go-home
Jun 4, 2008 03:50 PM
firefighter781
Feb 20, 2007 01:50 PM
Hawksram
ATC 3-Wheelers
Jan 5, 2006 12:03 AM
warwgn
Oct 25, 2004 12:23 PM
