quadracer problems, need help
Old May 28, 2001 | 07:52 PM
rooster06's Avatar
I have an 86 lt250r, and i just redid the whole thing. So after i got it back togeather i started it up and it ran for like 15 minutes, then i shut it down. Then when i went out the next morning to start it up there was moisturt all over it from the morning doo and it wouldnt start, when i went to kickstart it it back fires. And i have a realy weak spark, can anyone tell me what might be the problem. Any info. would be greatly appreciated.
Old May 28, 2001 | 10:16 PM
lt250rman's Avatar
You probly need a new CDi there $200 its either that or you shered the woodruff key, Its back firering because your timing is off. Did you put new piston and rings in to? Because my piston had a hole in it and it did the same thing.
Old May 29, 2001 | 03:09 AM
PENNZILLA's Avatar
Do you normally store your bike outside? This KILLS bikes. The cdi box maybe an issue, but it is usually the last to go. I would check the coil and plug wire first, then I would check the magneto and the coils behind it as well as the pick up. I don't believe that morining dew would have caused a problem in the other wiring but I would go through it and use electrical grease on all the plug in's before you hit some big puddles. One thing that may have occured during your 15 minute test run is that you vibrated a connection loose, I write all of this assuming that the test start up went well. If all of this is fine then have the local shop test your cdi box and look at your timing, I have seen a few bike that are 180 degrees out after a rebuild.
Old May 29, 2001 | 01:25 PM
shuttlemech's Avatar
You sheared your woodruff key. Take the side cover off and remove the flywheel. You will see the problem immediately.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
