lt 230 quadsport
stock w/ 12-41 gearing is about 45-48 mph. with a pipe you will be able to hold that 48, and get it to rev higher (maybe) so close to 50. with a pipe and a k&n filter, it pulls a 12-39 (57mph)really well
Need help before i burn this lt 230s. It vibrates all the time baaadddd. Checked the mounts they are fine . This happenes when you give it gas it does not put all the power to the ground it vibrates on the handlebars on the seat the whole fn thing . I put a new clutch new fenders , rear shock,chain swing arm bearings, axle bearings ,2 extra motors and rolling frame .alot of money. I hate this thing. Help!!!
CDI's hardly ever fail. its usually in the stator assembly. sometimes it also can be the coil mounted on the front of the frame.
if anyone is truly interested in knowing what speeds lt230s are capable of, click on the link in my sig and go to SPECS/INFO. i have a speed chart in there, that show what sprocket combo and speeds you can get.
