Help!!! Someone with a Zilla manual!!!
Old Sep 25, 2001 | 12:54 AM
waynaferd's Avatar
Can I have it? No, seriously, could someone please tell me what to torque the A-arm, Swingarm, and Cushion lever bolts too? I know how they go together and that the bolts in back hafta go in from a certain side, but I have no idea what to tighten them up to. I know its silly to do a rebuild without the manual, but I haven't got mine yet and the A-arms are all painted purty and the swingarm's been welded and I have everything needed to bolt them on, except for the torque specs......thanks alot.....
Old Sep 25, 2001 | 01:20 AM
Slinger's Avatar
Swingarm pivot nut: 36-58 lb.s
Cushion lever center shaft nut: 58-87 lb.s
Cushion lever pivot shaft nut: 58-87 lb.s
Wishbone arm end mounting bolt(upper and lower): 87-123lb.s
Wishbone arm pivot bolt: 36-50.5lb.s
Upper wishbone arm end nut: 25.5-36lb.s
Lower wishbone arm end pinch bolt: 29-43.5lb.s
Front hub nut: 36-58 lb.s
Front wheel set nut: 14.5-22.5lb.s
Tie-rod lock nut: 25.5-40lb.s
Tie-rod end nut: 16-25.5lb.s
All shock absorbers: 29-43.5lb.s
Rear axle lock nut right: 11-18 lb.s left: 115.5-144.5lb.s
Old Sep 25, 2001 | 10:25 AM
waynaferd's Avatar
Jeepers, Slinger, that's perfect. Thank you!!
Old Oct 26, 2001 | 02:17 AM
waynaferd's Avatar
Clint Russell
Sep 25, 2015 03:20 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Alex G.
Sep 19, 2015 06:34 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
