carb question (lt250r)
Old Jan 20, 2002 | 05:32 PM
chuck1221's Avatar
i recently got my quadracer all put back together. I took it for a ride today and noticed that when I shut it off a little gas comes out of the lower overflow hose on the carb. Is this normal?
Also when I try adjust my idle using the idle screw on the carb the idle doesn't change at all, I can screw it all the way in or take it all the way out and it doesn't make a differance. any ideas?
chuck
Old Jan 20, 2002 | 07:36 PM
250rampage's Avatar
You may need to adjust the float height on your carb back to factory spec's. It shouldn't leak. Are you sure your getting the idle screw, not the low-end air/fuel screw? I know that on some carbs, you have to wick the throttle open for a second before the idle changes at all after you mess with the screw.
Old Jan 20, 2002 | 11:54 PM
chuck1221's Avatar
thanks for the help. I will check and adjust the float if neccesary.
-chuck
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
