lt 500 reed help
Old Apr 28, 2002 | 10:53 PM
gnjeff's Avatar
on my 87 zilla i wanted to check the reeds to see if they are aney good. some dont close all the way just a little tiny bit of light can be seen. now when i bought the bike last month the guy gave me an extra cage with 2 big reeds on the top and bottom.now the one i took out of the bike has 4 little reeds on the top and bottom and looks better than the other one. if i go and get reeds for it if they are bad witch ones should i try to get?
thanks for the help..[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 29, 2002 | 10:37 AM
Duneaddict's Avatar
Sounds like the one that you pulled from the bike is the stock unit. They are an 8 petal setup.
FMF among others makes reed cages with only 4 petals.
Reeds need to seal against the block. Sometimes you can get a little extra life out of them by simply turning them over. (But it's only a short term fix)
Personally, I'd get a set of Boyesen replacement reeds for the stocker, or if you want to upgrade, go with a Mossbarger reed cage.
I'm not impressed with the FMF setup.
Just my $.02
Hope this helps
Old Apr 29, 2002 | 09:48 PM
gnjeff's Avatar
thanks for the info im going to the shop to get some new reds tomorrow.and see what they have.
Old May 10, 2004 | 01:03 AM
chilliwilli's Avatar
Default lt 500 reed help
Hey i also have 87 zilla bought new boyseen reeds an thought the same thing, i could see light in some not all of the stops these were new reeds i tried to flip them over but no luck with a seal. What would one do in this case i been running the quad since thats maybe 50-60 hrs at the most, would i notice a big difference if i could get a nice tight seal around my reeds. Any info greatly appreciated THX.
Jay
Old May 10, 2004 | 09:19 PM
waynaferd's Avatar
Hey Duneaddict...Any more info on where to find the Mossbarger cage? I have the Ram Valve but feel I could better.....Thanks!!!
Old May 11, 2004 | 06:34 PM
Duneaddict's Avatar
Wow, this is a pretty old post that has resurfaced... I've learned a few things from when I was touting the Mossbarger cages.
I did some pretty extensive testing with the mossbarger unit, and when said and done, I sent it back to them... The signal response with my big carb was horrible...
As of today... I can't recommend them any more-so than the others..
Here's what I'm currently running:
For the '87 (big reed), The stock cage with some decent petals (No dual stage crap) either TDR or stockers... with ~3mm trimmed off the stops, open the stops so as they barely fit into the cylinder, and use a 3/8" spacer..
This setup works great! Not much $$$$ either.
Old May 11, 2004 | 07:06 PM
waynaferd's Avatar
Thanks for all the info!!
Old May 13, 2004 | 11:42 AM
gotmuddy's Avatar
I run pyramid's, because they came with it, and I am happy with them. The throttle response is sick.
Old May 14, 2004 | 06:57 PM
waynaferd's Avatar
Is that a cage or just petals? Thanks!!
Old May 15, 2004 | 05:51 PM
gotmuddy's Avatar
It's a cage and petals. I had a mossberger carbon fiber reed and cage, but sold it.(might have been for an '87) I liked they looks of it more than the pyramid, although I am sure the pyramid flows more.
QuadRiders
Oct 22, 2015 04:13 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
