z400 speed
#22
well i've ran my z with a stock raptor and 400 ex and out ran the honda easily but the raptor was another story! so being the deputydog that i am i broke out the handy-dandy radar gun! the stock honda run's 67 mph ( with 125 lb or 300 lb rider on asphalt)the z 400 ran 70 mph and the raptor ran 78 mph. i would like to thank that the z would out run the flagship yamaha but that's not the case. note: sence that day i've installed a set of racing cam's and a header pipe with a jet kit . after the retest i will let you know the outcome.
ps. the 36 mm carb. on the z is to small for the z after the cams and pipe. i but a 165 jet in the carb and the pipe became transparent red! so i took the jet and drilled it out . some were around 190 maby 200 and back the air/fuel out to 1.5 . throw the air cover lid away ,with it on the z falls on it's face!
#23
well the cams and pipe did not improve the z's top speed but the start and mid range went throught the roof! half way down the quarter mile the z is at top speed. so for higher top end it looks like new sprockets are next to buy. i ran another honda 400 with a sparks 416 kit on it( as well as some other goodies on it)and lost by a two bike lead. the sparks honda ran 72 to 73 mph . so i can't wait two see what the z is going to do after the 440 kit is installed.
ps. the sparks honda was no match for the raptor running at 78 mph.
