Changed front sprocket on Z
Old Jul 25, 2002 | 09:40 AM
zookyridr's Avatar
Orielly auto parts. They had them in stock. You will like the gear change. You lose a lot of the top end but if you ride in wooded and hilly areas like Chadwick you very rarely get out of 3rd gear anyway.
Old Jul 25, 2002 | 08:21 PM
Corpsie's Avatar
What holds on the stock front sprocket and why can't you reuse it? (aka why the need for the 7/8" c-clip)
Old Jul 25, 2002 | 08:52 PM
250EXcited's Avatar
Zookyridr, Got the sprocket installed, thanks. I actually had to grind off a little of the flange so I had enough room to get the C-clip on. That's what I get for buying a cheap sprocket. Anyway, I can really tell the difference. It pulls alot harder in every gear. Especially noticable in 4th and 5th. On the down side, I did lose some top end, but you get there so much quicker its worth it. It also made the vacuum carb delay more noticable. Feels more like a 2-stroke now. I think a new carb may have to be the next mod. Corpsie, The stock sprocket is held on by an off-set spacer that is attached directly to the sprocket by 2 bolts. Kind of hard to explain, maybe someone could post a pic.
Old Jul 25, 2002 | 11:10 PM
Corpsie's Avatar
sounds like I should have gotten the 13 toother before hitting the dunes on saturday *doh*
I'll try to remember to post how well the Z400 handles 22" Realtors with the stock gears.
JackTheKing
Jul 14, 2015 09:09 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
tporath
Jul 11, 2015 12:31 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
