88 LT500 has a pee hole......
Old Sep 23, 2002 | 03:38 AM
Mr350X's Avatar
Hey people, my Zilla started leaking all its coolant out a small hole on the bottom of the water pump.
I changed the coolant, and aside from a drip or two here and there, it seemed fine. (last night at Glamis) Any idea what this hole is for????? My bros 86 LT250 has it also.
Old Sep 23, 2002 | 05:50 AM
FrenchGuy's Avatar
Between the water pump seal and Bearing is normaly were the peehole is located.
When the seal gets worn out, water will drip from hole to let you know it's time to
change your Waterpump Seal before the water get into your Oil.
I think if you check out www.eastcoastatv.com web site there use to be OEM parts Diagram
this should give you a good idea what I'm trying to explain.
Good Luck!!
Old Sep 23, 2002 | 07:20 PM
enginman17's Avatar
if you want to look at some diagrams of the quadracer and oder parts go to www.ronnies.com this is where i get my parts for my quadracer 250r.
Old Sep 24, 2002 | 06:07 PM
Raptoryfn660r's Avatar
RIP Dear Friend
I am not familiar with the zilla but when there is fluid leaking out of the weep hole I would think its time for a new coolant pump.
Chet
VP KNOWSALOT FACILITY
Old Sep 24, 2002 | 10:46 PM
theTICK's Avatar
The seal is bad on the back side of the impeller. You need a new mechanical seal and oil seal. When you take the bolt out of the impeller it is REVERSE THREAD! The leak happens all the time, It is an easy fix. If left to long the water will mix with the case oil then it is a big mess! Good Luck
mudmunster
Aug 29, 2001 01:44 AM
AussieZilla
Jul 11, 2001 01:05 AM
UofABB
May 25, 2001 03:08 AM
4x4rocket
Mar 20, 2001 12:18 AM
cctman
Sep 19, 2000 10:28 AM
