90 lt500 problem, need help
Old Oct 27, 2002 | 08:05 PM
fast1's Avatar
Default 90 lt500 problem, need help
Hi all...
Just got a 90 zilla and it's popping out of second gear, either into neutral or 3rd. Anyone know if thats the shift fork or is it the gear? Thanks in advance!!!!!
Old Oct 28, 2002 | 05:15 PM
kehale's Avatar
TTT
I can't help ya, but I'm sure someone can...
-T
PS: Get that thing runnin' for tomorrow.
Old Oct 28, 2002 | 05:27 PM
VegasQuadracer's Avatar
The dogs on the second gear are most likely rounded off and will slip out of the gear they mate to. Mine does it occasionally at the dunes when under a high stress situation like climbing a steep hill. If yours slips out rather easily, you should replace second and third at the least and do the case inserts while your at it if you haven't already.
Old Oct 28, 2002 | 05:41 PM
kehale's Avatar
Thanks Vegas,
Fast1 is outside tearing up the cases (at his house).
I'll phone him with the info.
-T
Old Oct 28, 2002 | 10:13 PM
stormnorm's Avatar
Check the detent lever spring. Mine broke 2 weeks ago and was sliding out of gears either into neutral or third. An obvious hint is that it would not click into gear like before. That spring holds a gear tight into gear. The spring is $2.50
Old Oct 28, 2002 | 10:20 PM
fast1's Avatar
thank you! it's apart and the springs ok...getting a new one anyway....
Old Oct 28, 2002 | 10:23 PM
ge500r's Avatar
I just got done dealing with that problem,on a 90.It's hard to say anything impiticular with out cracking her open,but there is a very good chance it's a bent or worn fork, or bent fork shaft, or a fork to gear clearance issue.I just bought brand new fork's and they came on the low side of the tolerance almost out of spec (I LOVE HONDA). but it could also be a that the shifting drum,pawl's,pawl springs,or cam stopper(shift drum stopper)spring,is worn. i was building a new engine so i replaced it all and it worked but in most cases i've seen everything i talked about will show some wear, so unless some thing sticks right out as being the cause, it can be tricky to diagnose.And if you try to cut corners theres a good chance you'll be craking her open again (NOT FUN).Tranny's can be tricky...........
Old Oct 28, 2002 | 11:19 PM
fast1's Avatar
yup sounds like my prob. everythings worn.....
Old Oct 29, 2002 | 01:43 AM
Ballz2theWallz's Avatar
This sounds a little stupid but my 87 was doing the exact same thing with a rebuilt engine and tranny , and all that was wrong was I somehow managed overfill my crankcase by 100 - 150 ml of oil and it made my tranny do all kinds of neat things like not shifting out of some of the gears , and popping out of other gears , I was sh!ttin myself for a while thinking I screwed up putting it together and I was going to do it all over again , drained out the excess oil and I was good to go. [img]i/expressions/face-icon-small-wink.gif[/img]
Always check the simple things first
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
