LT250R Drive Sprocket Seal Replacement. Easy?
Old Nov 28, 2002 | 12:57 AM
mrbones's Avatar
Default LT250R Drive Sprocket Seal Replacement. Easy?
I got a big oil leak coming out of the shaft that the drive sprocket mounts. Is this an easy replacement? I changed one once on my old Honda 200s a year ago. I had to gouge it out with a screwdriver then put the new one in. Is the LT250R the same way?
The leak does automatically oil the chain, which is kind of nice, but also slings it all over the place. And eventually the oil would run out and havoc will reign in the tranny.
Thanks
Old Nov 28, 2002 | 02:02 AM
dinksdairy's Avatar
Its easy, I had the same prob, it wasn't the seal. Theres a small oring in there and mine just disapeard. Take the spacer out and see if you have an o ring. If not, I put a thicker one than stock, fits more snug but I figure its less likely to leak if its pressed a lil more.
baysport
Jul 23, 2015 11:37 AM
trouttracker
Jul 20, 2015 11:54 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
