LT 230 S Carb replacement
Old Dec 11, 2002 | 09:55 PM
b1yjg51's Avatar
Default LT 230 S Carb replacement
I bought a 87 LT230s, sort of a basket case. Engine runs strong, no leaks, smoke, or bearing noise, but it looks like the carb is just worn out. The idle set screw has worn a divot in the side of the throttle slide, and the needle looks live an old toothpick. Couple of questions...What kind (make, model) replacement carb should I look for. I would like near stock performance and I don't want a lot of modifications. I am not sure if the carb that I have is stock, so I don't know if I should just replace what I have (choke linkage doesn't seem right)
Also, it looks like all the bushings and bearing in the swing arm need replaced. Is there anything special I should look for?
Thanks
bzdok1234
30
Feb 23, 2016 01:55 PM
coolguy420
Jul 10, 2015 01:17 AM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
