Quad starting Problems!
Old Feb 9, 2003 | 02:39 AM
RollinDeep's Avatar
Default Quad starting Problems!
My quad is nearly impossible to start by kicking it. The only way to get it to start without kicking it for a hour is dragging it and even then it dont idle or run smoothly. My first thoughts was the carb which is stock but every thing seem ok in that dept. it gettin plenty of gas(i dont know if enough) and plenty of spark. I dont get why it dont start. I talked to alot of people and they lean me towards a compression problem and some tell me a timing problem. Any advice or suggestions
Its a 1989 lt250s quadsport stock all the way around.
Old Feb 9, 2003 | 12:16 PM
LT250RSuperstar's Avatar
I would take it to the local shop or something. I have a 250S also and have no problems except the swingarm breaking and shock wearing out. Maybe the valves need adjusting.
My 2 cents
Old Feb 9, 2003 | 01:28 PM
LT80's Avatar
LT80 Expert
I guess that I'd agree w/the ones you've asked so far. Do a compression test! Did you do a thorough carb cleaning? (pilot jet plugged?)
Old Feb 9, 2003 | 01:53 PM
JSsDS's Avatar
Sounds like nothing a good carb cleaning wouldn't cure. Most likely a plugged pilot jet. This is the smallest jet in the carb so its first to clog when the quad sits for extra long periods of time. Most dealers can do this but if you know someone that is a good mechanic you can save some money by having them do it.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
TJM
Jun 11, 2015 01:28 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
