Z400 Cold Weather Starting Problem
Old Feb 10, 2003 | 09:07 PM
Zoinks!!!'s Avatar
Default Z400 Cold Weather Starting Problem
I was going to say the prime setting as well this will more than likely get it started!
Old Feb 11, 2003 | 09:07 PM
jaws's Avatar
yea i know about the prime setting but ive never had to use it, it was about -10 here the other day and my z fired right up with the valve set on ON. so RAPTONOWNER ur saying the newer z's dont have the fuel cutoff ne more, i got my z back in august and i was just wondering if suzuki has changed ne thing on the newer z's since mine
stock z 400
Old Feb 11, 2003 | 09:14 PM
87RaceRider's Avatar
Jaws I couldn't follow you there. Are you saying you have a fuel cutoff. I got my Z in Dec and I only have an On and Prime setting. I tried it again today and there was no problem starting. It must have been that it sat for a three weeks while I let my sleds stretch there legs.
Old Feb 11, 2003 | 09:50 PM
RaptorOwner's Avatar
What I was saying that the Z is a new bike and they dont have a off on the fuel valve just on and Prime. Prime is for COLD weather. Its controlled by vacuum so you dont have to have an off on the valve. You can actually remove the fuel line off and it wont pour the gas out, just tricle out whats in the line itself.
Old Feb 12, 2003 | 08:20 AM
  #15
MegaCrash's Avatar
Its because of the fuel valve. It lets the carb gas evaporate out of the bowl if your quad sits for a couple weeks unused, then when you are trying to start it up, the motor isn't turning over fast enough to make vacuum. Kind of a stupid feature if you ask me.
Put in prime for a couple minutes, let it fill up the carb bowl, put it back into the on position, then she should fire up for ya.
In the cold a 4 stroke will require some patients though, just the nature of the beast.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
