quadracer axle and suspension q's!!!
Dcopp, a spanner wrench is the correct tool to use to set the preload on the front, but you can get away with using a small pipe wrench also. Just be careful not to damage the body, but it will work. On the rear a spanner wrench is the way to do it too, but if necessary, you can use a punch and hammer to break the lock rings loose. This can damage the lock nuts though if you are not careful.
