How much can the ozark pull
Old Apr 26, 2003 | 11:06 PM
Ozarkrider03's Avatar
Default How much can the ozark pull
Im thinking about buying a trailer hitch and im just wondering how much the Ozark can pull? THANKS!
Old Apr 27, 2003 | 12:53 AM
Coyotechaser's Avatar
I've read that it's limit is 730 lbs. CMP has hitches in Shade Tree for about $25.00. Gosh, I know more about your quad than you do.
Old Apr 27, 2003 | 10:21 PM
I knew it was 730. I was just wondering if it could pull more because It says the back rack can only hold 66lbs and I had a box of dirt on the back that weigh like 200lbs lol. It was squated down pretty far though.
Old Apr 27, 2003 | 10:41 PM
The recommended amounts are probably suggested for the safety of the buyer. Although certain machines might be able to pull more weight.
The recommended amounts for the racks are probably suggested also for the safety of the buyer. If you put too much weight on the racks it can effect the handling of the atv greatly.
Old Apr 27, 2003 | 11:51 PM
mojave300ex's Avatar
Just pull as much as you are comfotorable with, I mean you can tell when a machine is being overpulled just don't dog the motor down and keep it in the low gears and you should be able to pull way over the limit.
Old Apr 28, 2003 | 10:34 PM
Luecker's Avatar
The towing limits are based on being able to safely stop the load you are towing. A bigger machine with hyraulic disc brakes is going to be able to stop better than a small machine with drum brakes.
I am sure your ozrark could pull a couple thousand pounds pretty easy. But it will push you when you want to stop.
Old Apr 28, 2003 | 10:41 PM
Thanks guys! Anymore opinions?
Old Apr 29, 2003 | 06:21 PM
suzuki4ever's Avatar
I used to put my 18' boat in and out of the water with my 88 lt230E. The quad was rated for like 600 pounds and the boat weighted 3400 pounds. The only problem I had was traction because it was on a stone launch and keeping it from pulling me down the hill was the hardest part. It had the grunt though. It had no problem pulling it out in first gear.
Old Apr 29, 2003 | 07:01 PM
thats a lot of weight!
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
SDR-II
Sep 29, 2015 01:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
traumajunkie
Jul 5, 2015 03:03 PM
