vinson problem
Old May 1, 2003 | 09:20 PM
petersonfred's Avatar
Default vinson problem
I just got my new vinson 5 spd. on tuesday, and I am already having problems. It starts sputtering and choking when I put the throttle down to about half. I can't figure out what the problem is. I am taking it to my dealer tomorrow but I thought I might be able to save myself a trip.
Old May 1, 2003 | 09:33 PM
pairof98s's Avatar
You might ask the dealer if it is necessary to re-jet from the factory setting. I assume you are at high altitude and it may be too rich. Also could be an air leak around the carb boot. Good luck.
Old May 1, 2003 | 11:34 PM
SuzukiQuadrunner160F's Avatar
is there water in your oil or airbox, if so get a polaris.
Old May 1, 2003 | 11:48 PM
tb1602's Avatar
Mine did the same thing as i put on same miles on it , it went away.
Old May 2, 2003 | 12:25 AM
MnTurboPaws's Avatar
...maybe its the carb needle and seat..dirt stuck in it....ar a stuck float...
Old May 3, 2003 | 10:32 AM
MrVinson's Avatar
Sometimes if you accidentally leave the choke open the plug will load up and it will run terribly. Just a thought...
Old May 6, 2003 | 09:46 AM
Unlucky1's Avatar
I was riding one day in the woods and had a similar issue. I found out that a plug behind the engine had gotten disconnected. The problem was very similar to the rev limiter in reverse.
Old May 7, 2003 | 04:47 PM
Pastor's Avatar
Whatever you do...DON"T get a polaris....you'll be sorry.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
