Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Grizzly 660 problem Please Help!
Old Apr 19, 2009 | 11:30 PM
  #21
DEALER1's Avatar
Did anyone ever find a fix for this? Mine is doing the same thing. Every gear including park and neutral. If you try to give it more than 1/4 throttle it pops,sputters and backfires. It acts like it would if you were in reverse trying to back up fast without using the override.
Old Jun 21, 2009 | 04:49 PM
  #22
tlstefan's Avatar
I've got the same problem..there's no way it's fuel related it's to consitent to be that it has to be electrical. NEED ANSWERS
Old Aug 9, 2009 | 12:58 PM
  #23
rschaub's Avatar
Default Check the reverse lever
There is a reverse rev limiter located on the little arm that makes contact with the clutch lever. When you put it in reverse you push the button which makes contact with the lever. If the lever does not return to its stop it will not let the motor rev. Reach under the clutch lever and find it and push it back to its stop. If the reverse cable sticks it will cause the problem. My raptor has the same set up and the same problem...good luck.
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
hondarider1234
Jul 21, 2015 11:53 PM
MATT BOOTH
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
