Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
ATTN:SMART PEOPLE
Old Apr 12, 2008 | 09:41 PM
  #21
chadsmith660's Avatar
Default ATTN:SMART PEOPLE
well i can relate i am having the EXACT same problem with my 03 grizzly 660 and i'm 98% sure it is the woodruff key i have no idea how it got broke but when the piston is at TDC the timing marks aren't close to lining on the crank sprocket gunna go at it tomorrow and see what i find
Old Apr 14, 2008 | 03:58 PM
  #22
justincohee's Avatar
wow ! aright heres how you can eliminate the guessing game shut off the fuil to the carb remove the spark plug squirt about a table spoon of gas into the cylinder replace the spark plug start the engine if it starts and runs for a couple seconds then the electrical is fine next repeat the same test only into the carb throat if it runs the valve timing is fine and it truly is the carb that is the problem if it fails check the fly wheel key since you'll have it off replace it then repeat the afformention test if it still fails the look at your valves a side note just don't over doit on the gas or it'll flood remember isolate and eliminate
shimanok2
Jan 29, 2016 07:37 PM
kbazzy
Sep 26, 2015 11:26 AM
Irishman301
Sep 23, 2015 01:47 PM
01ssls1
Sep 22, 2015 06:50 AM
Elkaholic
Sep 6, 2015 02:44 PM
