Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
electrical know how?
Old May 14, 2008 | 09:36 AM
legleg339
Guest
Posts: n/a
Default electrical know how?
howdy , id like some info on charging voltages and such on a 110 cc quad mines got a loncin motor running a 12v system, the lights are everyday kinda thing youd use in the tail lights of your car , dual filament for the rears and single for the front , low wattage for lows and a higher for the high beam i was wondering what sort of voltage it should be producing to keep the battery charged and also how i can test the rectifier, regulator, and stator coils , at the moment it runs the battery flat if i use the lights , i have taken one of the 5 wires off the stator and run it straight to my high beams so they are nice and bright but i think ive made the charging prob worse , is there a way to beef up my power supply without spending a butt load of money ? im in australia so any bnits i get will most likely have to come from overseas so any backyard mods i can would be great , any ideas?
Old May 14, 2008 | 11:12 AM
upnort's Avatar
"NORMALY" at the battery running 2-3000 rpms you should have over 14 volts. Coming out of the stator should be at least 18 vac. Lead to lead on a stator should be a fairly low resistance reading like 6-8 ohms. Do not know how you would be able to boost your system. I take it that there has been some mods done already. A stator will only put out so much wattage. I know you can get aftermarket stators for some machines but that may cross over into the buttload area.
Old May 14, 2008 | 11:31 AM
legleg339
Guest
Posts: n/a
i checked the stator at the connectors coming out of the housing i get about 25v ac at the battery terminals i get around 6v dc at idle and havent been able to get much more than that , is there a a way to test rectifiers and regulators ? nothing much in the way of mods mechanically stock except for the exhaust which being a cheap chinese model the baffles came apart so i cut the end off the muffler and pulled the guts out lol sounds good tho and elec wise all ive done is simplify the rest of the lighting wiring si i dont have so much extra junk laying around everything else is stock tho i havent changed anything to do with the stator etc cos i dont know a great deal about them im new to the quad bike scene having come from working in a police garage things are a bit different lol i measured the stator at 5 ohms so any other ideas would be greatly appreciated cos im wearing out batteries and chargers lol
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
