Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Lubricating Suspension Part
Old Jun 1, 2008 | 09:35 PM
ATV-1's Avatar
Default Lubricating Suspension Part
I have a honda recon, and my girlfriend has a 250ex. I do regular maintenance like oil changes, etc. but I don't know how to lube the A-arm pivot points or the ball joints. There is no zerk fitting so I can't just give a pump of grease. Do these parts just need to be replaced? That sounds expensive. The suspensions on both quads squeak a good amount now after several years of riding in dusty terrain.
Does anyone know what's done on the suspension of these machines to keep them in top shape?
I've looked in the threads and have only found recommendations to grease the parts, but no instructions on how to do it...
Thanks,
Paul
Old Jun 1, 2008 | 10:59 PM
NJDale's Avatar
You grease the ball joints and tie rod ends with a 'Grease Needle' attachment that you put on the end of your regular grease gun. You DO NOT actually 'pierce' the rubber boots - you go 'under' the rubber boots at either end of the boot. Here is a link to a picture of one (this one seems expensive - I think that they go for $8 to $10;
Grease Gun Needle Picture
As far as the 'A' Arms go - you usually have to remove the 'bolts' and then get grease into the joint area that the bolt came out of (needle might be good for this also) then reinsert the bolt and re-tighten the nut (maybe cleaning grease off bolt threads and then using 'blue' loctight), for all eight 'A' arm bolts.
While you are at it you should also 'take apart' and grease the 'rear swing arm bolt and bushings/bearings' ( the 'really big long bolt' that the swing arm pivots on).
Oh yes, then do the same to all three shock mounting bolts (top & bottom), along with cleaning the grease off the bolt threads and using 'blue' loctight on each of these.
Old Jun 2, 2008 | 12:39 AM
ATV-1's Avatar
Awesome!
Thanks for a straightforward and clear answer. Much appreciated...
Paul
Bratman2
Aug 6, 2022 01:42 AM
Asaran
Oct 8, 2015 11:14 AM
toonces
Aug 5, 2015 05:55 PM
Polarisman1123
Aug 3, 2015 02:08 PM
Jkfx400P
Jul 6, 2015 10:04 AM
