Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
suzuki LT-4wd electric problems(no spark)
Old Aug 21, 2008 | 12:06 AM
Wannagofast83's Avatar
Default suzuki LT-4wd electric problems(no spark)
Hello all,
Just got a quad from a friend that had is to fix but never did, now its my turn. Its a 91 Suzuki LT-4wd It will crank but does so hard, If I remove the spark plug it does so freely. Seems like too much compression??
Also Ive notice that the spark plug isn't sparking. Also to get it to turn over I Have to jump the connections on the solenoid, could this be related to the above. Some of the the other forums posts, that they say the kill switch could be a problem(short). The switch is a key with on/off and lights.
Does any one have a wiring diagram for these machines.
Any ideas/ things to check?
thanks
michael
Old Apr 12, 2009 | 07:33 AM
tjmoor's Avatar
Hi,
Congrats on the new ATV. I have the 1998 model and had a dickens of a time getting it started. I finally noticed that there is a small lever that goes up and down next to the starter button on the left side of the handle bars. It appears that up is choke off and down is full choke. Don't know if you know about it or not, but I would check that first and hope it helps. Let me know if you need any other help.
Tim
Old Apr 12, 2009 | 04:10 PM
tjmoor's Avatar
Also check for wet or fouled plug, defective magneto, defective cdi unit, defective ignition coil, an open or short circuit in high tension cord.
Bigredjeep
Apr 10, 2020 02:55 AM
njrider64
Jul 4, 2017 01:40 AM
merryman
Jun 27, 2015 03:31 AM
jag6510
Jun 15, 2015 05:59 PM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
