Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Atv Pulling to the Left
Old Sep 17, 2008 | 04:01 PM
aaarneson's Avatar
Default Atv Pulling to the Left
I just bought a 2005 Yamaha Kodiak 450 and it is pulling to the left a little. I am not sure how this happened. Does anyone know what could be causing this or what I can look into?
Thanks
Aaron
Old Sep 17, 2008 | 04:15 PM
lowlife's Avatar
make sure your handlebars are straight and measure the distance of each tire to the center of the frame. In other wordes measure from center of tire to center of frame on each side. Do this to both the front and back of the front tires. You should notice that the tires are towed in about 1/4 inch on both sides. If they aren't then you will have to do an alignment. If they are ok then check your ball joints and a-arm buchings. It could be a sign of them wearing out. Lastly I would check to see if each wheel (when lifted) spinns freely. this could be a sign of wheel bearings going bad or a brake sticking. Good Luck!
Old Sep 17, 2008 | 11:17 PM
dfreelang's Avatar
I had one do that it was a low back tire
Old Sep 17, 2008 | 11:42 PM
aaarneson's Avatar
What is a good psi to run the tires at? The max is 36psi but I heard the tires are usually really low.
Old Sep 18, 2008 | 02:44 AM
user493's Avatar
Moto Psycho
Isn't it supposed to around 4 psi?
Old Sep 18, 2008 | 04:46 PM
95wolv's Avatar
Jumbofrank, your new avatar is scaring me!!!!
To stick to the topic, the 36 psi you saw is maximum to seat the bead,an ATV tire should never be above 10 psi, most of the manuals show anywhere from 2.9 to 5 psi,depending on the model and tire type.
Old Sep 18, 2008 | 04:58 PM
mdj104's Avatar
i run 6-8 psi.if one side is low it will pull.
Old Sep 19, 2008 | 04:18 AM
user493's Avatar
Moto Psycho
<div class="FTQUOTE"><begin quote>Originally posted by: 95wolv
To stick to the topic, the 36 psi you saw is maximum to seat the bead,an ATV tire should never be above 10 psi, most of the manuals show anywhere from 2.9 to 5 psi,depending on the model and tire type.</end quote></div>
I see you got a new av too. I get bored easily and when I came across a superhero I never saw called Doctor Polaris I thought hey, I'll give him a try.
As for tire pressure everything I've seen is around 3-5 psi according to the ATV manufacturer and usually 7 to maybe 10 max according to the tire manufacturer. I don't think I've seen one as high as 36 to seat the bead but I have seen about 28-32 on some. I can't imagine riding it that way.
Old Sep 19, 2008 | 09:50 AM
95wolv's Avatar
Got my new one off MSN news, there was an article about a Saudi Sheik who has declared that Mickey Mouse is a "soldier of Satan",standing for all that is wrong with the "decadent American lifestyle". Funny, we even mention the name "Mohammed" and they are ready to go to war, but they see nothing wrong with trashing an American Icon like good ol' Mickey !!!!
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
akbrewcrew
Aug 9, 2015 10:54 PM
cornermike
Jul 30, 2015 06:37 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
