Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
bearing problem 03 warrior
Old Sep 22, 2008 | 11:07 PM
Yamahaha1's Avatar
Default bearing problem 03 warrior
Hey I am new to the forum and just bought a 2003 yamaha warrior yesterday. Ok I have pulled off the wheel and cannot take the Hub off the axle to replace the bearings. Is there something i missed? I thought that after I removed the bolts, tire, unhooked the front brake pad majig? Maybe it is rusted on or something? Suggestions please
Thank you, Austin
Old Sep 25, 2008 | 12:09 AM
jason_westfall's Avatar
Good luck. I have been working on one also, heat it up and beat like hell. The seals go bad and let water in so everything rusts together. I have mine all apart except one bearing sleeve thats frozen solid to the axle, my next step is the grinder. Oh, I heated up the housing at each end and kinda melted the seals out, then kept heating and driving the end of the axle in the ground while holding the housing. It's the only way i could beat without messing up the threads.
Old Sep 25, 2008 | 12:34 AM
Yamahaha1's Avatar
how did you heat it up? setaline torch or something? and did you heat then hammer or how?
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
honda71
Jul 12, 2015 05:56 AM
