Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Grease nipple problems on Polaris 2001 and 2004 Sportsman
Old Feb 26, 2009 | 12:55 AM
The Highlander's Avatar
Default Grease nipple problems on Polaris 2001 and 2004 Sportsman
Have just purchased a new grease gun and cannot remove the coupler from the nipple. Had the same problem with my new Polaris brand (made in China) grease gun and have thrown it over the back fence.
What am I doing wrong or is there a particular type of nipple used on Polaris ATVs'
The Highlander
Old Feb 26, 2009 | 06:22 PM
The original Firehawk's Avatar
I had a similiar problem with my coupler. Try to push the coupler on at an angle and once it clicks straighten the aligment and it should stay put. To remove, don't pull straight off, angle the coupler off... First few times will be difficult.
Hope this helps!
Old Feb 26, 2009 | 07:18 PM
Thanks for that Firehawk, tried it and it works. Took five or six goes for the coupler to free up enough to allow me to remove without having to apply too much pressure. At least I now have a decent grease gun. My next effort is to try and stop one of the front wheels from locking in when in two wheel drive. Can happen at any time from a start. May post another thread to see if anyone else has this problem.
Thanks again for you help.
Old Feb 26, 2009 | 08:30 PM
<div class="FTQUOTE"><begin quote>Originally posted by: The Highlander
Thanks again for you help.</end quote></div>
No problem, hope you get an answer on the front wheels. You lost me on that one.
Old Jun 26, 2009 | 06:11 PM
weasel85's Avatar
check the fluid in the hub that is locking up if thats not the problem you will have to take the hub off and clean the four wheel drive clutch then re assemble and add fluid i had the same problem on mine
njrider64
Jul 4, 2017 01:40 AM
Jbird4681
Jun 9, 2015 01:59 AM
UPLou
Jun 7, 2015 09:42 AM
Thor
Aug 28, 2000 05:14 PM
karter16
Dec 6, 1999 11:20 PM
