Anyone ever restore faded platic
#23
I sold professionally online for many years and believe it or not the best thing I have found to use is clear coat spray paint. We called it rebuild in a can. Not only will it seal vacuum leaks but it will restore faded paint quite nicely at the same time.
#24
I have used this method....worked pretty good..was impressed
Been there done that i recently bought a 02 grizzly 660 red it was sun faded so bad couldnt even tell it was red, if you clean it off with brake cleaner or any cleaner... i used paint thinner, then take a brand new razor blade hold it at a slight angle towards you then push down and drag toward you scraping the plastic do this all over the faded areas until its all the same color then you can either leave it like that or put clear coat on it or use a heat gun and melt the top layer slightly to make it like new hope it helps worked wonders on my griz
#25
Had no idea you could bring back plastic by scraping off the faded. That would be fairly time consuming on an ATV though. I've seen some old red ones that are pretty much pink they were faded so bad.
vinrum
11
Aug 26, 2015 06:44 AM
Cantbuytime
Aug 17, 2015 06:33 PM
