Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
carb question
Old Apr 20, 2009 | 07:27 PM
vindell's Avatar
Default carb question
Took carb apart at shop, followed a fellas advice on a how to site, took some time, but I beleive it's clean, sprayed alot, covered a few holes and reprayed, back and forth, cleaned all jets, and what not. noticed bowl gasket is broken, missing around an 1/8 of an inch. also in the cleaning I seemed to have lost a little o ring for the throttle adj screw. Will either of these two thing's decrease performance. The quad seems to take off, great low end then seem's to level out. any other ideas, it's a 2005 eton 70
2 stroker. stock bike. the only thing I did was removed the oil injection system. Must the thing be re=jetted, since the oil system has been removed
Old Apr 29, 2009 | 08:00 PM
boudro13's Avatar
the o ring will keep dirt out of the throttle cable without it u might end up with it sticking and having to b replaced sooner & as long as ther fuel bowl isn't leaking i wouldn't worry to much as long as it is running corectly.
Old Apr 29, 2009 | 09:08 PM
vindell's Avatar
appreciate the input, not to change the thread but removed clutch cover, the belt seems to be loose can touch it together when sqweezed in the middle, is this ok ? checked rollers, seemed ok, not sure what im looking for but they all looked the same. belt is a bando 70 16.5 30, got some advice to switch to a polaris belt. have the size written down, the fella, paul reimer, great fella, said it was 10mm larfer, and would give it more top end. tha front variator seems to have around a 1/2 inch of unused travel. any input would be appreciated. Vince
Old Apr 30, 2009 | 04:55 AM
vindell's Avatar
sorry 780 16.5 30 belt
Old May 12, 2009 | 02:55 PM
budsbuds's Avatar
Default need help too
I think I need to take my carb off n clean it, where did you find a site to do that?
Old May 21, 2009 | 12:12 PM
ltz_rider's Avatar
i just bougt a 2004 ltz 400 i just had the motor rebiult i put it all back to geather and now when i go to start it it revs up and i can still push the gas and still has some throtle response does anyone know where the idle screw would be located on the bike
Old May 21, 2009 | 03:49 PM
vindell's Avatar
Google how too clean a two stroke carb.
Old May 24, 2009 | 09:33 AM
JeffinTD's Avatar
If a two stroke starts to rev up with the throttle at idle, it may have an air leak between the carb and engine, or around the crank shaft.
I think I'd also try to find a replacement for the float bowl gasket. I wouldn't want dirt/grit to migrate in there.
Not sure about needing to rejet when removing an oil injection system and switching to premix, but I would think it would make the mixture slightly leaner. Would probably have to try it and see how it runs.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
