Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
tming problem on warrior 350?
Old May 29, 2009 | 07:39 AM
djk0106's Avatar
Default tming problem on warrior 350?
Is it at all possible to be 180 degrees out of time? My warrior has spark, fuel, and compression and the valves are set correctly. Put a new piston and rings in the bike and it will not start not even with a shot of starting fluid. Timing marks line up but I an getting some air back through the carb and wondered it it is 180 degrees off. Any help would be appreciated. Thanks.
Old Jun 3, 2009 | 12:07 PM
Doctorturbo's Avatar
GOT BOOST!
Sure; it's just a chain that turns the cam. You can have it one tooth off or a 100 teeth off or anything inbetween.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
