Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
carb problems
Old Sep 22, 2010 | 09:13 AM
zandersdad's Avatar
Default carb problems
I have a 06 Kawasaki 400 that I bought used. I put a fresh top end and cleaned the carb and took it out and rode it and it was great the next day I had a hard time starting and then it died in the woods. towed it back and found that it would only start and run with the choke on. I have gone thru the carb 3 times and still have gotten no were my thoughts are it is getting too much gas because when I push the throttle it dies. any one got any ideas
Old Sep 22, 2010 | 10:42 AM
Jaster94's Avatar
if you push the throttle and it bogs down and dies, your carb is still dirty. clean the jets thoroughly. blow air through them, clean again, check for daylight in the orifices. check your float operation. check all nooks, crannies, and channels. if it bogs, you still have dirty issues with the jets.......sorry, it's got to be as clean as factory. trust me, i've had the same problems and that's what works for me.....
p.s. i use an oxy/acetylene torch tip cleaning tool pack to clean my jets.....if it's any consolation, i've cleaned the same carb as much as 6 times in one setting to get it clean. hang in there!
here's a sticky hyperlink that'll help you.
http://forums.atvconnection.com/kids...ttle-dies.html
Old Sep 22, 2010 | 01:02 PM
JeffinTD's Avatar
Be sure to blast some spray carb cleaner through all the passages and every little hole in the throat of the carb.
If it only runs with the choke on, and bogs when you apply throttle it is likely starving for fuel. Make sure the float level is right, and if it has a fuel filter screen on the petcock, make sure to clean that.
Old Sep 23, 2010 | 08:28 AM
zandersdad's Avatar
thanks for the advise but took carb off 3 times yesterday with no help to the problem. ordered a carb rebuild kit to see if that helps. one guy told me it could be a valve or timeing isse as well any thoughts on that
Old Sep 23, 2010 | 02:55 PM
JeffinTD's Avatar
It wouldn't hurt to run a compression test and check the valve gap and timing, but my best guess is still that you have a fueling issue.
Old Sep 30, 2010 | 02:58 PM
Seopard's Avatar
If it'll still start, will it tickover and if so, for how long?.....
Old Oct 5, 2010 | 11:08 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Have you checked out the fuel system from tank to carb? check to see if fuel is coming out of petcock? is petcock assy.[fuel shut off] vaccum type?
Old Oct 8, 2010 | 08:17 PM
KQ400Pilot's Avatar
Check the diaphram on the CV slide-- a pinhole can cause multiple problems.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
