Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Vinson Carb Problem
Old Jan 20, 2011 | 05:45 PM
yankees2bills51's Avatar
Default Vinson Carb Problem
I recently took my carb apart and out in a stage one jet kit. Before i took apart it didnt run right either would only go about 11 mph. I put the jet kit in and all i get is 22 mph. i cleaned everything but i do remember looking through the pilot jet and not being able to see through it. Could the pilot jet prevent it from going over 22. When it ran good it ran easily in the 50s. Now full is only at 22mph. Thanks
Old Jan 20, 2011 | 07:51 PM
papahouse's Avatar
Pilot jet could be the problem or not getting enough air
Old Jan 20, 2011 | 08:13 PM
07 400's Avatar
you might have to rebuild carb fuel pump might be getting weak and not pumping enough gas. also take carb spray when you have carb apart and spray through every jet and make sure it goes through the passages and comes out where it should.
Old Jan 20, 2011 | 08:36 PM
I have a k&n on it
Old Jan 25, 2011 | 10:32 PM
07 400's Avatar
is your filter clean. might not be getting enough air
Old Jan 26, 2011 | 08:12 AM
TLC's Avatar
TLC
I put a wire through the jets to makes sure there open. Disassembly and Cleaning of a Mikuni Round slide Carburetor
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
