Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
ATV carb operation question
Old Jan 30, 2011 | 01:26 PM
rdeeno's Avatar
Default ATV carb operation question
I just got my AC running, it has a 98 model 300 motor and carb on it. Once it is warmed up, whenever you take it out of gear, the idle goes up high. It idles fine in gear and runs great. Whenever the idle goes up, if I open the fuel enrichment valve (choke) it will idle back down. Since the fuel enrichment gets it air from the diaghram area, I assume the diaghram is going up (when it shouldn't) and the fuel enrichment circuit is taken its pressure away when open. So in the end, I guess I need to either add spacers to the spring or get a stronger spring for the diaghram? Thanks
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
