Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
CAT Back Up Light
Old Feb 20, 2011 | 06:14 PM
Nolanoutdoors's Avatar
Default CAT Back Up Light
I am either getting old or lazy, maybe both, but I decided to install a “backup” light on my ATV. This will make closing gates and unloading in the dark much easier and safer.
Warn Winch makes a Back-Up light that will provide all the backup lighting I will need. The kit comes with a 35-watt H3 halogen bulb mounted on a universal mounting bracket, wiring harness and a water resistant switch. The light is designed for ATV use.
First I disassembled the “dash” on my Arctic Cat 650 H1 TRV ATV. I picked a spot adjacent to the speed odometer to mount the water resistant toggle switch.
After routing the wires and securing them with wire ties I connected the wiring harness direct to the ATV’s battery.
Lastly I routed the lights wires and mounted the light.
That’s all there was to it, about an hour and you will be backing up in style.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
MrElussive
Dec 12, 2000 05:13 PM
trx430ex
Nov 15, 2000 01:26 AM
