Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Quad will only bump start
Old Jun 28, 2012 | 07:30 AM
cshehwen's Avatar
Default Quad will only bump start
I have a Honda trx 450er and it will only bump start. Runs fine after that but if i let it sit for a half hour it wont start. The starter sounds normal... Im thinking its the battery. Any other opinions??
Old Jun 28, 2012 | 08:07 PM
woodsidewarrior's Avatar
Check your valve clearance . You may have a intake valve that is not closing all of the way.
Old Jun 28, 2012 | 09:24 PM
Jaster94's Avatar
i had an old quad that was the same way. intake valve adjustment and the problem went away.
Old Jun 30, 2012 | 06:34 PM
DanWarrior's Avatar
Might be the stator/magneto, my warrior would only bump start. I replaced it and fired right up.
Old Jul 3, 2012 | 07:37 AM
cshehwen's Avatar
Put a new battery in and nothing changed. I found out there was a decompressor recall for the 08 450er so i took it to the honda dealer. I told them to do the valves too. Keep you posted
SOLOLUCKY
Oct 4, 2024 09:09 PM
neilbedwell
Nov 10, 2018 11:02 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
1000gade
May 27, 2015 12:37 PM
