Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
New to quads, please help
Old Apr 1, 2013 | 03:26 AM
jamesmccoyldl's Avatar
Question New to quads, please help
A couple days ago I was riding my quad (150cc automatic) and I wanted to see how fast it could get up to so I decided to just press the gas all the way and enjoy the ride. When I did this it did a popping noise, I believe it was backfiring. After that had happened I immediately started losing momentum and jerking a lot. The next day when I started it up, I pressed the gas down to start riding and it immediately died, i turned it back on and tried again, same thing happened, then I started it and let it idle for a minute, and it died without me hitting gas, so I did this again and let it idle for 20 seconds, gave a little gas and then we were good to go, but the backfiring still occurs and the jerking. Also the backfiring occurs when i accelerate.
Old May 28, 2013 | 12:28 AM
Pstroke96's Avatar
Check the plug maybe fouled
Old Jun 10, 2013 | 02:37 PM
idnative1948's Avatar
Also check your wiring connectors. Those are notorious for shaking loose or having a wire come out of a connector. I have taped most of mine.
Old Nov 12, 2013 | 12:52 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
That backfiring is telling you that it is wounded. If the plug and wiring is good to go, you may have burned a piston. That popping is caused by a lean condition and that generates heat big time. Timing is usually the culprit. I would push it on the trailer and take it to the dealer post haste before you have a catastophic failure and it costs you way more than you can believe.
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
