Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Help needed
Old Apr 10, 2013 | 09:10 PM
marktz96's Avatar
Default Help needed
I have a 2002 Arctic Cat 400. The ATV has NO electrical power even when the the key and on and off switch is on, but when the ATV is started by pull starting it all the electric stuff works. What is the problem?
Thank you
Old Apr 23, 2013 | 10:36 AM
madmadman's Avatar
here's a link to the wiring diagram 2002 Arctic Cat 400-500 FIS WIRING HARNESS ASSEMBLY | CyclePartsNation Arctic Cat Parts 1st
Old May 28, 2013 | 12:25 AM
Pstroke96's Avatar
Probably a bad positive contact between the key switch and the battery try jumping the selonoid if it starts then start at the battery with a test light and work your way towards the key switch if you have power all the way then you may have a bad switch
Old Nov 12, 2013 | 12:59 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
The old Honda Warriors used to be notorious for bad grounds. Especially if it saw a lot of mud riding. The emergency kill switch was a problem area too.
Sjrpp
Jul 5, 2015 09:04 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
