Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
no spark after getting hot
Old Aug 16, 2013 | 02:42 PM
jmbco3's Avatar
Default no spark after getting hot
i have a 96 polaris xplorer 300 and it runs great till it warms up and then it looses spark has anyone else had this problem iam leaning towards the coil but not real sure
thanks in advance
Old Aug 16, 2013 | 05:47 PM
Check stator wires to cdi,then the coil. Stator exciter coil wires (Black/Red to Brown/White 120 ohms) Coil primary(coil tab to ground 0.3 ohms) Coil secondary (coil tab to plug wire,cap removed, 6.3k ohms) Plug cap itself (3.7k ohms to 6.3k ohms) Resistance specs are + or - 20 %
Hopefully this can help you narrow down the problem if it's electrical. Not a bad idea to check compression also. This is a symptom of low compression also. Runs good until hot,then dies when rings lose seal against cylinder wall.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
