Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2002 Polaris 500 stuck in gear wont shift out of high or low
Old Jul 18, 2015 | 07:42 PM
micheleLeigh's Avatar
Default 2002 Polaris 500 stuck in gear wont shift out of high or low
Im stuck in gear and cant get out or into low or high. I removed linkage and still nothing. What's wrong? Also the forward/reverse indicator light works intermittently? ??????
Old Jul 19, 2015 | 07:32 AM
Common problem as the linkage ends and shift box components wear and get slack in them over the years.
Possible hydro lock on the gear shift box that many have done over the years from wear. Loosen the 10 mm lock nuts on the rod ends,remove the linkages from the gear shift box. Pop the gear shift into neutral,use vice grips on gear case belcranks and rock the atv back and forth until you can get the gear case into neutral. Check how much free play the shift lever has when the linkages are removed. If you have a lot of slack,adjustment may or may not help or may not last long.Adjust the rod ends in or out until they drop straight into the shift box levers with NO resistance.Then tighten the rod end lock nuts. Hopefully this can help.Plus again any wear items may need to be replaced if you notice a lot a of free play back and forth on the shift lever while it's in neural. A good fluid change wouldn't hurt also. 0w40/5w40 oil to where it barely covers the gear box shift levers.http://www.cyclepartswarehouse.com/f...2002&fveh=5582 Gears have to be fully engaged for the gear indicator switches on gear case to transmit the gear position to the speedo.Items 12,13. http://www.cyclepartswarehouse.com/f...2002&fveh=5582
gfl0224
Jun 27, 2015 06:52 PM
Dakosk
Jun 6, 2015 05:37 PM
Fullblast
May 26, 2015 12:38 AM
Ursus
Oct 1, 2000 12:28 PM
caldwell
Oct 28, 1999 03:30 PM
