Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
2004 sportsman 600 electrical issue. Need help ASAP
Old Dec 12, 2018 | 08:28 AM
Lyle1984's Avatar
Default 2004 sportsman 600 electrical issue. Need help ASAP
I have a 2004 Sportsman 600, I am having an issue with when the machine is cold as in below freezing weather, you turn the key on (with the kill switch on) there is no power. The cluster doesn't light up the head lights won't come on and it won't crank. I have replaced the battery, key switch, kill switch and the winch solenoid. The only other things I have done was replacing the base gasket, and upgraded the ignition system. But the problem persisted before that. Has this happened to anyone or anyone seen this and have any fixes or suggestions? Thank you.
sp600blue
Dec 12, 2018 11:22 AM
mal15
1) Engine problems..
Jun 22, 2016 08:47 PM
1988rrc
Jan 6, 2013 02:39 PM
Kane Hart
May 18, 2009 12:31 AM
Cowman
May 16, 2003 04:57 AM
