5th wheel toy hauler
I had an F150 but switched to a Cummins Ram 3500 when I started thinking about a 5th wheel toy hauler...
There may be a couple of options that could be within your ratings...
KZ makes a 25' job, for example, with a dry hitch weight of 1100, and GVWR of 8,000 pounds...
What are the payload and trailer weight ratings for your truck? (I would still recommend a bigger tow vehicle if you can swing it).
My GVWR is 6050lbs or a GCWR 10000lbs. My manual says max trailer weight of 5500lbs, but is for a hitch trailer, doesn't say for a 5th wheel . I assume regardless of type it can not exceed 5500lbs. I was hoping there was a small 5th wheel toy hauler, around 20' out there some where.
badgerboy1
09-26-2017 06:11 PM
10-10-2015 10:20 AM
