Towing help
Old May 2, 2005 | 11:05 AM
Dynamics1369's Avatar
Default Towing help
I have 2 polaris sportsman 500HOs. and a 14ft trailer. The quads wheigh say 800lbs a pice. and the trailer is between 500-1000lbs. ill say a 1000lbs to be safe. so the question is will a 2005 Toyota Tacoma pull 2600 lbs easy? The truck is 245hp, 282ft-lbs, standard towing is 3500, and max is 6500. do you guys think i would have any problems?
Thanks for the help....
Old May 2, 2005 | 11:32 AM
MeYHymN's Avatar
Default Towing help
It should tow it fine. It'll probably suck the gas mileage and speed out of the truck, especially on long, steep grades, but you'll be fine.
Old May 5, 2005 | 12:39 PM
PERM01's Avatar
Default Towing help
Not a problem, I used to tow my two wheelers with my wifes v6 blazer all the time and you didnt notice it that much. You'll be fine.
Jeff Roper
Feb 1, 2022 11:48 AM
Customer Service #1
May 15, 2020 08:46 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Alex G.
Sep 19, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
