1992 chevy silverado towing capablities?!?!
Old Mar 2, 2006 | 10:31 PM
blasterofdisaster's Avatar
Default 1992 chevy silverado towing capablities?!?!
i have a 1992 k1500 4wd silverado with a 5 speed manual trans, and a 5.0 305ci engine, this spring break we are goin to bull gap, i was wondering if anyone has ever towed with the 5.0 liter engine and what kinda of mileage i would be getting, and is there any precautions i should take being that it is a manual transmission????? thanks kyle.
Old Mar 3, 2006 | 09:46 AM
Bump Plz.
Old Mar 3, 2006 | 12:56 PM
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
Max towing probably is in the 5-6K pound range. Depending on tires, rear gear, etc.
With the manual the ony thing you have to worry about really is trying to take off on a grade, but it probably won't be an issue.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Mar 8, 2006 | 12:07 AM
bump, anything else?
Old Mar 15, 2006 | 01:49 PM
James400EX's Avatar
What are you towing????
Old Mar 15, 2006 | 05:12 PM
1bad450r's Avatar
Well when I had my 96 chevy with a Vortec 5.0 liter and auto tranny in it I was getting probobly 16mpg on the highway pulling my ski boat. It pulled fine. But my vortec had a little more juice stock compared to your throttle body engine.
Old Mar 23, 2006 | 10:26 PM
i will be towing a blaster, a yz125, on a 2 place tilt trailer, and a ttr 125 and a yammy xt350. nething else?
Old Mar 24, 2006 | 08:46 PM
calsatman's Avatar
your truck will pull this without problem, just use common sense and watch your temp gauge try not to lug the engine in the hills. watch the road ahead and if you see a hill coming up gas on it and get some speed before you get to the hill, that way when you top the hill your not down in third gear running 45 mph. i sold my 96 siverado and i pulled some heavy loads on a gooseneck trailer with this truck. trailer weighed around 2500-3000 lbs and had a 2wd modified class sled puller truck that weighed 6200 lbs i hauled every summer. just use common sense and youll be fine. you should really consider adding a trailer brake controller because if you pull often the brakes will not take the abuse.
Old Mar 26, 2006 | 11:44 PM
Sidekickmechanic700's Avatar
like stated before, you should be fine hauling that load. do what was said, watch the temp, take inclines correctly.
as far as gas milage, with my 97 5.7L auto, loaded with my 700 and a receiver carrier loaded, i was getting 18 mpg.
ReconBayou
Oct 31, 2022 05:37 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Alex G.
Sep 19, 2015 06:34 PM
