stiffer springs
my dodge 1500 sport is the best truck ive every had it does every thing but the suspion in the rear and front are soft. when i stand in the bed it moves to much and when hauling wood it squats a good amount. i dont understand y becuse the truck will pull it no problem.? can i just get hevy duty springs for it but where? please help thanks
Depending if you want to retain your factory ride when empty, you can either add a leaf to your existing leaf pack, or add a set of helper springs. I added a leaf to my 98 f-150 because of your same situation you are having with your truck. One word of caution however, it will make your ride stiffer after the leaf is installed. You can purchase an add a leaf on-line at summit or somewhere like that and install them yourself if your mechanically inclined. Otherwise, I'm sure some alignment shop or similar business could install them for $150 or so.
Technically, your not supposed to load your vehicle past the manufactures GVWR. The rear axle should also have a maximum weight rating. On most stock half ton pick up trucks, 1500 pounds is the maximum you are "supposed" to load into the truck. When I added the leaf spring to my truck, it raised the rear about 1.5" and I could load up 2000-2200 pounds before the truck would come close to the bump stops. I wouldn't advise going on public roads doing this because you are over your vehicles weight ratings and if you are involved in an accident, all sorts of nasty things can happen.
1356 pounds is the listed payload for a 1500 sport, with a 6,350 gross vehicle rating. It likely has 275/55R20's that are likely rated around 2800 max load.
Anyway, airbags would be my choice to help with sagging, but there's more to payload capacity than springs, and they don't change the ratings listed in the door jamb...
Personally, I wouldn't exceed the gross vehicle weight rating or the axle ratings if I could help it.
If you are at or over your weight rating and want to legally haul more wood without getting a heavier duty truck, how about a trailer?
I put helper springs or Overloads on my 1500 Ram, I hate them. They make noise, they aren't really adjustable, and they hurt the ride when unloades. I put these on my 2500 Ram and wouldn't trade them for anything. I added an aircompressor and would definitely recommend them......
http://www.suspensionconnection.com/...tion/to=r.html
