ATV Trailer with Mobile Home Axle
I am looking at a 6x12 trailer that used a mobile home axle. The seller told me that he replace the bearings on one side and the cost was $90.00 for parts. The trailer was built three years ago and it is selling for about $400.00. Not sure if the axle is an issue, but I do not have any experience in buying trailers.
Thanks
Thanks
It uses a mobile home axle or an RV axle? Either one is massive overkill for a 6x12 unless the axle came off a pop up camper. Even then it should be fine. RV axles are usually outsourced oem equipment, most manufacturers are using just a few companies for axles. Chances are good you wouldn't have trouble finding bearings for it when needed.
I'm not a big fan of mobile home axles, unless it's a kick around the farm type trailer... Usually they reuse the springs, too, which ride rough.
If I were spending all the time and money to build a trailer, I think I'd put a Dexter or Al-Ko axle of the correct rating under it. Most RV's use one or the other, and they aren't as expensive as you might think.
You might check out etrailerpart.com
My buddy has a mobile home axle on a much bigger trailer. It was still too little trailer weight and the axle bowed up in the middle. He cut it in half and re-welded it an an angle where the tires sat flat on the ground. I pulled it with 5 (or 6?) quads on it, and fully loaded it pulled so easy it felt like there wasn't even a trailer there. My 5x8 with one quad usually sways and bounces around enough so that I can tell it's there without looking.
