Combo ATV / PWC Hauler
Old Jul 8, 2008 | 11:33 AM
BEER SEASON's Avatar
Default Combo ATV / PWC Hauler
Howdy yall,
I am just looking for a little trailer purchasing advise. I am in need of a trailer (preferably aluminum) that will haul two ATVs and two Seadoos at once. I have looked high and low and not found any mfgs tha make such a thing. I have mocked this idea up on my freinds 4 place triton snowmobile trailer. When it's loaded it's fine, but take the quads off the front it will darn near lift the back end of the truck off the ground. I always end up filling the truck bed with camping gear and coolers so not much use there for a quad(s). Does anyone know of any trailer manufactures that would make such a trailer? Or any ideas at all for that matter? I have toyed with the idea of moving the axles on a snowmobile trailer to accomodate the loading but I would like that to be my last resort.
Thx,
beerseason
Old Jul 13, 2008 | 07:23 PM
SMFREY's Avatar
That sounds like a challenging issue to resolve
Have you thought of making the PWC rack on wheels that can be secured to a trailer
This could resolve several issues
Loading and unloading PWC in and out of trailer and water
Weight shift when Quads not on trailer they can be moved forward
Possibly look at the small trailer/hand carts used for the snowmobiles and figure out how that can be used to raise and lower PWC on small hold rack
Just some thoughts may be a simple resolve
Good luck
Ray
Old Jul 16, 2008 | 05:50 PM
TheJcode's Avatar
That 4 place trailer, 2 ski's on one side and 2 wheelers on the other. Instead of 2 loaded front and 2 back. Make one long 2x4, braced all the way up the trailer as needed. Wanted to really put forth the effort, definitly a crank to slide the first one forward, but maybe one that rotates up for the second. Since the 2x4's will be raised it can hide under there to load the first one. A bracket on the back side of the middle crank to tie down the back of the first ski and one/both quads. AS for unloading, I'd think it being on a loading ramp in the water, the incline and a buddy would be enough to unload it.
Just a thought?
Old Jul 16, 2008 | 07:58 PM
no1's Avatar
no1
on pop up campers there are stabilizers on the front and back, they drop down from the frame to the ground. why not fab. stabilizers for the back of the trailer that will come to with in 3 inches of hitting the ground. This will allow you some clearance for the ramp while keeping the back of the truck from getting to light while unloading. A stabilizer could be as simple as a piece of square tube stock welded vertically on the outside back of the frame. Then find a piece of square tube stock that will fit inside the piece that is welded on the trailer. When the longer inside piece is 3 inches off of the ground clamp it and drill a hole through both pieces for a pin. Then repeat the process with the stabilizer in the up position for traveling.
Old Jul 19, 2008 | 06:15 PM
JeffinTD's Avatar
Here I figured this thread would be about how to haul your PWC/Qaud combo...
Quadski
Old Jul 19, 2008 | 07:13 PM
firehog's Avatar
Try www.diamondbackcovers.com. Maybe this would work for ya. Hauls two atv's, leaving room underneath cover for storage and then haul the pwc's on a trailer.
I have seen some homemade jobs that haul both. Maybe get with a local welding/fabricating shop and see what ideas they would have.
Old Apr 6, 2009 | 01:32 PM
Dande's Avatar
Here you go;
http://sporttrailersinc.com/
Old Apr 6, 2009 | 07:09 PM
smk8er's Avatar
Thumbs down
What about altering a pontoon boat trailer? quads up front or on one side and PWC's on the other side or in the back... just a thought
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
mitchxc700
Aug 19, 2015 02:41 AM
tpd270
Jul 5, 2015 10:38 PM
wildbill59
Jun 9, 2015 02:28 AM
A400L
Aug 15, 2000 04:21 PM
