Installing winch...HELP!!
Old May 25, 2003 | 02:10 AM
TeddyTwoFire's Avatar
Default Installing winch...HELP!!
I have a kodiak 450. The winch is bolted on. I need advice as where to install solenoid and where to put control switch thingy. any other tips will help.
Old May 25, 2003 | 01:46 PM
Coyotechaser's Avatar
What kind of winch do you have?
Old May 25, 2003 | 03:15 PM
Warn winch, I now have solenoid mounted under right side of storage box Under seat (on the out side) just left of muffler about 6-7 inches. I ran the + cable the batt. (just enough cable to make it). Its tucked under nicely wire too. sooooo should I mount the control switch thingy on hanle bars or ?????
Old May 25, 2003 | 08:53 PM
It would be good to wire the switch to the handle bars, so you can reach them and the throttle if you have to give it some gas. I had mounted my switch on the rear part of the front rack. I thought it would enable me to reach the switch and the cable. Also I don't really have room on the bars because of the speedo. But since I've used it a couple times. I'm going to try to mount it on the bars by the light switch on the bars. Warn has a switch that fits around the light switch. (Kinda L shaped)
That way it is in alignment with the other switches. You can also buy a key chain remote switch from Ramsey for your Warn.
Old May 25, 2003 | 08:56 PM
My winch had 2 wires that came from the battery to the switch and 2 wires that came from the winch to the switch. ( I realize that Warn may not have 4 wires.) Hope something helped a little.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
