synthetic oil
Old Feb 17, 2004 | 06:56 PM
sok's Avatar
sok
Default synthetic oil
My rancher dosnt shift into 3rd gear after starting up.Its manul shift. unless i use my hand. After that when its warm its find.Using 10w40 think synthetic would help? Thanks!
Old Feb 17, 2004 | 07:59 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I don't think synthetics are compatible with the bikes autoclutch.
Old Feb 17, 2004 | 08:25 PM
huskerjim's Avatar
use the synthetic without...moly you will be fine
Old Feb 18, 2004 | 10:52 AM
Aramis's Avatar
I use synthetic oil in my wolverine and it works fine...
Just make sure you dont use oil that has detergent or other stuff like it...
Another thing to avoid, if the bottle has an "energy conserving" label or mention on it, avoid it...
Mine runs on Motul motorcycle oil, i think it's the 3100
Runs great, never slips...
Aramis
Old Feb 18, 2004 | 11:03 AM
NLWarrior01's Avatar
Dunno if there's a difference in auto and manual clutches, but I use Mobil 1 15-50 in my Warrior. Got about 2000km on it so far and it still looks brand new!!
Old Mar 28, 2004 | 09:52 PM
mudrunner12345's Avatar
Amsoil makes a synthetic oil for ATV's 0W40. It's made to use with a wet clutch.
Old Mar 30, 2004 | 01:52 AM
Lightman's Avatar
Sok, if you are riding in very cold temps, the petroleum based oil's viscosity at low temps may be a problem. Synthetics certainly flow and protect a LOT better in cold temps. Otherwise you could possibly have worn out oil, or need adjustments to your quad..hard to speculate.
Guys, detergents are a good thing in oils. What you don't want when you get a synthetic oil for your quad is one with friction modifiers in it. Typically, synthetic oils that are designed for motorcycles will have friction modifiers removed, which is why they are preferable to automotive synthetics of the same viscosity range. I have had great results with amsoil synthetic 0w40. Another good one is Mobil 1 MX4t 10w40.
cornermike
Aug 10, 2016 06:47 AM
Alex G.
Sep 19, 2015 06:34 PM
Haakon
Aug 24, 2015 01:54 PM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
toonces
Jul 31, 2015 09:27 AM
