REAR DIFFERENTIAL
Old Apr 29, 2004 | 06:41 PM
roperdog's Avatar
Default REAR DIFFERENTIAL
are there any atvs out there that have a rear end that is similar to a car (one tire turns faster than the other while making turns/power to one whee) = tighter turning radius.
one with a locking rear end would be ideal
thanks
Old Apr 29, 2004 | 07:36 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
All the ones with a solid axle (most of the bikes out there) have a "locked" rear end, by default. It is the bikes with IRS (independent rear suspension), thay have to have some kind of "locker" to keep both wheels turning.
Old Apr 30, 2004 | 12:35 AM
bigbamaboy's Avatar
The only one that I know of is the Polaris ATP (All Terain Pickup). It has regular 2wd, with a locked rear axle, the Polaris AWD system, and a switch that unlocks the rear axle, and lets it turn on a tight radius like a car. This allows the quad to be used on turf or in yards where you wouldnt want to tear up the ground in tight turns. There may be more outhere, I just havent heard of them.
Old Apr 30, 2004 | 01:04 AM
IndianaDude's Avatar
The Kawasaki Bayou 300 2x4 has a diff that you can lock and unlock.
I had one and it came in real handy for working in the yard.
Tuff machine, it took alot of abuse.
bigred20653
Oct 2, 2015 10:05 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
