clutch kit who is the best EPI or outlaw super duty
thanks for all the help you all gave me about where to get a kit for my 2004 450 kodiak. now whos is the best EPI or outlaw super duty clutch kit. thanks for you help. testomoy time can you really tell the defferents. any problem with them after you had it installed
It depends on your riding application. The Highlifter Outlaw is made specifically for large mud tires and does not give a whole lot of performance except to get you back to the stock feeling when you put mud tires on. EPI makes this kind of kit, but also makes a sport-utility kit that I've heard very good reviews about from several different makes of quads. This is supposed to help acceleration and sometimes even extend belt life slightly.
I have a 2002 Kodiak 400se ultramatic with a few addons. I added an EPI sport utility clutch with a lot of expectations only to be let down. It does help in the bottom end a bit but for the amount of top end that I lost to me it was not worth it. Mind you I am only running 25inch tires, with bigger tires there might be a difference.
2002 Kodiak 400 se Ultramatic
1.5 inch high lifter kit
25x10"front, 25x12.5rear Bearclaws
K&N filter
2500lb warn winch
Moose bumpers
EPI Clutch kit
K&N filter
2500lb warn winch
Moose bumpers
EPI Clutch kit
BYC
Sep 25, 2015 02:10 PM
